Old 05-31-2003, 06:00 PM
Cobra20646 Cobra20646 is offline
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Have to go along with Mr. Putnam...... the symptom of the pedal not coming back all the way.....
tie a string to the pedal to allow you to pull the pedal back manually. Then try to pump the pedal (assuming that the m/c piston followed the rod). If it gets hard and releases the clutch, either the return spring is in the master cylinder is shot, or you have some binding in the rod from the pedal to the m/c, or..... but at least you'll have narrowed the problem down.
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
