Old 06-02-2003, 08:42 AM
gfridland gfridland is offline
Cobra Make, Engine: Midstates 427 Ford FE
With both wheels off the ground, there is no effect from spinning one wheel on the other wheel. The car did run for about 1/2 mile (easy) before this happened in 1st, 2nd, and 3rd gears and let go in 3rd gear after which all forward and reverse gears were lost. The passenger side rear is completely loose and disengaged from the driveshaft based on how easily it turns as compared to the driver side. There is what seems to be a metalic clutch sound when the passenger whells is spun by hand. I do not think it is the brake rotor sound.
Gene
