Old 06-02-2003, 01:35 PM
Cobaby Cobaby is offline
Cobra Make, Engine: Unique, 351W, Toploader
Hey Guys, thanks for the replies.
Dexter - info pack reads cure time is 30 days. I waited 60.
CobERA - The coat did go on thin at first. As I realized I would have excess base coat, I put on a "little" extra. Therefore, I think it could be said that the area was not entirely consistant.
Snakeoil - You're right. The only way to do it is right the first time. My brother will be ordering in the future.
ohekk - Check with 1-800-ucoatit. It seems as though I read where very large areas could be sold cheaper and in larger quantities, but I'm not sure on that. Total cost to me was approximately $1.05 / sq ft.
Chaplin - this thread has confirmed my decision. The video and instruction book was great and easy. I followed both as close as I could. Know them well before starting.
Finally, on the subject of my original question, I called UCoatIt today and they stated that I should be fine and was not concerned about the thickness of the first base coat, or even the need for a second coat of base. Even with the rain, I can wait a day or two before applying the finish coat. However, they said time it so that 24 hrs after applying the finish coat, apply the Gloss AF on a day where the humidity was below 75%. This will decrease any haze to the final appearance that occurs when applied in high humidity.
I have no doubt it will turn out brilliantly!!
Hope this helps you guys as much as it helped me.
Cobaby
