Old 06-02-2003, 03:30 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You need a spring compressing lever. If you have a compression tester, you can use it's adapter to fill the cylinder with compressed air, but have the piston at TDC anyway.
