Old 06-04-2003, 01:31 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Cowtown-
David can give you better details than I can, but generally, the TKO II is stronger than TKO and the TKO is stronger than the 3550. The TKO II is considered the road race version of the TKO. The TKO II is rated for 475 ft/lbs of torque compared to 425 for std. TKO (I think those are the right numbers), has a stronger third gear than the std. TKO and fift gear ratio is .83 compared to.68 in the std. TKO.
I am certain that others can provide you more detailed info.
Replica is not a dirty word.
