Old 06-05-2003, 12:55 PM
Whaler Whaler is offline
Default ? on Enzo's front license plate bracket
Hi all, there has to be one person that mounted this puppy on their car??
Bought the front bracket for possible use. Where I live its a $75fine and a fix-it slip once pulled over for no front plate.
I was wondering about mounting at the park lamp end. I see it obviously attaches to the quickjack location but what happens with the signal lamp side?
Mine is drilled only in the center with a large notched hole thats smaller than the bulb's base. This plate also requires it to be drilled to allow the lamp screws to pass thru to the body?
Do some people not attach it to both the lamp and the quickjack/bumperette?
No instructions with the bracket
thanks
Tim
