Old 06-06-2003, 07:43 PM
ADR ADR is offline
Default 428 CJ and FE performance parts
428 CJ complete balanced rotating assembly.
.010/.010 crank
BHJ harmonic balancer
Reactor Products billet aluminum flex plate
ARP balancer bolt
new crank spacer (shelby)
Eagle rods
BRC flat top pistons (+.030)
Plazma moly ring set
Clevite bearings
Total seal second rings in bag
Interenal balance with mallory
Asking 2000.00
Moroso pan and pickup 150.00
MSD billet distributor 225.00
Sealed Power/ TRW +.030 forged pistons with moly rings
200.00
Set of Edelbrock heads fully ported and polished by Aire Reasearch Engineering. (John Haskell) with flow sheet.
Manley Gen II 2.15 SS intake valves
Manley Gen II 1.75 SS exhaust valves
Isky springs dual w damper for flat tappet cam
Titanium retainers w/ 10*comp locks
CV products valve spring seats.
Heads flow 300/245 @ .500 valve lift
Asking 3000.00
Sidewinder intake with plenum devider still intact. Lower side of intake flange welded and port matched by ARE manifold in good shape all screwholes good.
Asking 600.00
F427 port matched by ARE manifold in good shape
250.00
Comp cams roller thrust plate assembly ( upper cam gear needs machine work to fit ) 70.00
Speed-pro oil pump form shelby 50.00
All parts new / never used....selling all FE stuff
Thanks Dale
email DRober5410@aol.com
