Take a tape measure with you. Ask him if he ever measured the frame for "true" and what the results were. Most never have, so he probably hasn't either. BUT if he did and knows what your talking about it's an excellent tip off that the build is high quality.
The tape measure? Measure the outer wheel lips of all the fenders to the outside edge of the top of the tire. You may find that the rear left/right are a little different from each other. The front should be dead on. Around a 1/2 inch or so difference can often be found on even regular Detroit cars. Anymore that that and you got to start wondering if the "body" is aligned correctly or is the frame "funny". More often it indicates the body is not quite "perfectly" aligned with the frame when it was mounted. On the "cheaper" bodies, this can be a common problem. The body warps a little or shifts when you bolt/screw/glue it to the frame. Does the body mount on the frame with some kind of rubber isolaters? Or is the glass body placed directly on the frame? I prefer some kind of isloater myself, but it can work directly mounted.
You might want to e-mail him first and have HIM take the measurments before you get there. Lets assume wheel offsets are the same front and rear of course.
What about "ride height"? Bumper left/right front and rear, same height? OK,,,now what about the "frame", and/or body ride height? Same for both sides as measured in different places?
Again, bear in mind SOME difference could be considered "normal". It is hard to "see" a one inch difference unless your "looking for it". Then, it's "obvious".
Ernie
