Old 06-08-2003, 10:16 AM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
T-I-O
I THINK YOU SHOULD HAVE A CONVERSATION WITH MIKE STENHOUSE (SECOND STRIKE) IF YOU GET A CHANCE. HE HAS AN ALUM 427 FROM FORD RACING (RDI) EASILY PUTTING OUT THE NUMBERS THAT YOU ARE LOOKING FOR. LESS EXPENSIVE THAN SHELBY, BETTER QUALITY, NEW TECHNOLOGY, I COULD GO ON AND ON. I ALSO HAVE ONE PUTTING OUT 533HP AND 534 LB/FT IN IT'S STREET VERSION. I HAVE ANOTHER TRACK MANIFOLD AND CARB SETUP TO PUMP IT UP ABOUT 25-30HP; WITH NEW PROTOTYPE HEADERS I CAN ADD ANOTHER 50 HP, WHICH WOULD PUT ME WELL OVER 600HP. I CAN'T IMAGINE NEEDING THAT MUCH. EVERY EVENT I'VE BEEN TO, I HONESTLY BELIEVE I'VE HAD THE CAR AND ENGINE TO BEAT, ONLY PROBLEM IS THE DRIVER AND DRIVER'S SKILL LEVEL.
YOU ARE THINKING RIGHT WITH THE ALUM BLOCK!!!!!!!!!
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
