Old 06-08-2003, 01:13 PM
cobra427mnsi cobra427mnsi is offline
Cobra Make, Engine: Classic Roadster with 427 center oiler
Default Oil-pressure relief vavle
I have a '63 427 center oiler C3AE that I am putting together. All the machine work was supposedly done by Eagle Racing in Southern Michigan when I bought the block and all the parts. So far everything is at spec according to Steve Christ's book on Fe big blocks.
My question is about the oil-pressure relief valve found in the rear oil gallery immediately above the cam shaft. I pulled the gallery plug to check if the valved had been shimmed to increase oil pressure and NO valve to be found. Do I need the valve or can it be left out, since I have the high volume oil pump from Precision Oil Pumps which already has a pressure relief valve installed ? The valve in the pump has had the spacer install to increase oil pressure. I may remove it if the pressure is too high.
Any comments are welcome
Thanks
Paul
life is short: eat dessert first !
