Old 06-08-2003, 09:58 PM
decooney's Avatar
decooney decooney is offline
Default simple one...
If all else fails, try this. Jack up the front of your car (same height as if it's on drive up ramps), open the cap on expansion tank if you have one on your FE; making the expansion tank at the highest point.
If you have an expansion tank, and it trickles out small bubbles at a time, try letting it sit for a few hours or overnight. Be sure the tank is at the highest point in the system including hoses...
f you don't have an expansion tank, remove the water sending unit/plug instead on the front of your intake manifold (if you have one) and let the water trickle out there for a bit. Watch for air gaps as the water bleeds out the hole, then close it off after a fair amout of water has escaped with no air gaps there.
This has worked for me several times and never had a problem since with my last two Cobras
Duane
