Old 06-09-2003, 07:56 AM
SFfiredog SFfiredog is offline
IIRC if the plug is not located properly the oil pressure from the main gallery will just dump back into the pan. Or, you could block off oil supply to the rear main bearing. Both things are not good.
I just install the valve and shim up the spring to keep it closed. The bypass in the pump will do the job.
--Mike
They bend 'em, we mend 'em.
