Old 06-10-2003, 12:30 PM
tblackgt350 tblackgt350 is offline
Default 289 weber bellcrank
Does anybody run, or know of a weber IDA set up on a 289 that uses a central bellcrank instead of a side pull linkage(that runs properly) and does said set up use an intake that mounts the carbs with all fuel outlets on the outside, or two out and two in??
Thanks,
Tim
A good friend will help you move.
A real good friend will help you move a body.
