Old 06-10-2003, 07:37 PM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
Rick,
Well I dont want to insult you with the obvious ......so I assume you have checked the ;
water level
fan belt tension
also ...
stuck t- stat
ignition timing
stuck E- brake
blown head gasket
failed water pump impeller
if your water is up and your belt is tight, I would check your t- stat first. drop in boiling water and check temp as it closes
gooluck
KK
Foolish consistancy is the hobgoblin of tiny minds
