Old 06-11-2003, 06:31 AM
Charlie Charlie is offline
I notice most of your stroker build-ups are using AFR heads. Are these better than the Trick-Flow heads, and if your answer is yes, then can you give specifics? And what about the SVO GT-40 aluminum heads? Nobody seems to be using those, although coyled is using the Yates heads. I assume that means the GT-40 heads just don't flow well. Any opinions on this?
Charlie
