  #22 (permalink)
Old 06-14-2003, 11:36 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Take a look at Ron Francis Wireworks, and Painless Wiring for harnesses and electrical components.
You can make your own dash harness, or complete harness assemblies. Strip, crimp, solder, grease, and shrink wrap is tedious detail work, but payback is a trouble free electrical system. A trick I use is to draw a schematic first, then follow the schematic during assembly.
Test each circuit individually as you proceed.
And, if you honk the horn, and the headlights come on, go back to your schematic. Even pros make mistakes.
One tip I'll share is don't trust your frame to be your primary ground. If you wire all your grounds to a common point such as a bussbar, then wire the bussbar to the battery ground, your grounds will be consistent, and reliable. Ground the frame for redundancy. Put an extra nut on the starter mounting bolt, and ground the starter/engine directly to the battery ground.
