Old 06-14-2003, 09:07 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Default Double check your flight info
I posted this over on Gasholes.com as well:
With all the recent trouble the airlines are having you should verify your flight info at least a day ahead of time.
I am leaving on Monday June 16 for some quality time with the spousal unit before the fling and I just checked my flight info. Turns out they had cancelled my first flight. The didn't even notify me because they switched me to one that was less than an hour different.
Problem is I always get there about 40 minutes before lift off because I can always check in using the First Class line with my flyer status. They also have a cheater line for security when you do that so I don't bother showing up the suggested 1 1/2 to 2 hours early since curb to gate is usually only 10 - 15 minutes.
As it turns out they put us on a flight that leave 40 minutes earlier than what I had planned and considered that close enough to not have to notify me since I should be there 90 minutes early.
So you might want to double check things..
I better go confirm my rental car and hotel room now.
