Old 06-15-2003, 07:21 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Fxbill,
Also have CR, and it rides pretty smooth. Difference may be in suspension and shocks.
On rear, using Moog Chevette progressive wound load leveler springs which I think is the only replacement Chevette spring available. Shocks are Konis crossreferenced from the CR Monroe shock.
Fronts are tubular with Carerra coil overs.
Koni's and Carerras are adjustable, and I found softening them up took away some of the harshness that the stiffer 17's added.
