Old 06-18-2003, 10:02 AM
John S Peterson John S Peterson is offline
Cobra Make, Engine: Heritage body, built the rest..460 Toploader..9"
Usually when you replace the pinion seal, you measure the rotating torque with a inch pound torque wrench before dissassembly. When reassembling, install the flange, washer and nut, retorque to the same reading you got previously and add a couple of in/pounds. This has worked every time, and is the method I teach in my auto class. This is to say that you have no other problems other than a leak.
6year Heritage A&F
1969 Hurst SC/Rambler(only 1,512 made) in the middle of restoration.
