Old 06-18-2003, 12:00 PM
MPG MPG is offline
Location: Spring Branch Texas, just nort of San An, Tx.
Cobra Make, Engine: 1974 ??. GT40 302 roller cam, roller rockers, stage 3 SVO alum heads, T-5 tranny.
Question My mystery Cobra
HELP, I need some help figureing what manufacture my car is. Its a registered as a1974 Ford. the vin # in on the left side of the window mid way up the post. Its is a square tube frame simular to the B&B, (but is not one) Has a Mustang II or Pinto rack and pinion steering and front supension. The fire wall, foot wells and inner fender wells are all stainless steel covered. Two things that seem unique are the rear suspension and side pipe feed thru on the body. the rear supension is a half leaf spring. forward end attaching to the body (sandwich between a botton plate and the body. Has a upper link control arm and single shock that is almost vertical. the exaust feed thru on the body has a fairing formed on the body. Most any hard parts are traced to 72 or 73 . ie gears in the rear end, steering, brakes ect. It DOES NOT have an oil cooler air scoop below the front. It does have a newer 351w, SVO alum heads and Tremec five speed. Tryed to post a photo but would not take. I can e mail some if anyone thinks they can help.
Mike Garvin
