Thread: Footspace
Old 06-18-2003, 03:54 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Some of you guys with a tired left leg might benefit from adding a "dead pedal" to the left of the clutch pedal. Basically a little rest about 1" wide or so, attached to the kick panel, that you can rest your clutch foot on while cruising. Just make sure it won't interfere with your actuating of the clutch pedal. (older) CR's don't have enough room, their footbox is narrow.
