Old 06-18-2003, 06:10 PM
Denny S. Denny S. is offline
Default Could You try another please on DeskTop
Custom Grind By Comp
11-1 Edelbrock, 870 Carb, Tubes with mufflers same set up as before ..
Gross Valve Lift INT 515 EXH 525
Duration @ .006 Tappet lift
INT 262 EXH 270
Valve TIming @ .050 LIft
Open 3 BTDC Close 35 ATDC
43 BBDC 3 ATDC
CAm installed at 106 Int CL
Duration @ >050 INT 218 EXH 226
Lobe lift INT .298 EXH .304
Cam GRound with 108.0 lobe seperation
THis is a custom gring the ( Ford EXpert )
at Comp gave me for boatloads of low end torque.
THank You in Advance ....
