Old 06-19-2003, 05:03 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If you want to play with your Holley, get replacement metering block and fuel bowl gaskets (many), nylon bowl screw gaskets, an assortment of: vacuum secondary springs (if applicable), pump cams, squirters, jets, power valves, bowl vent baffles, and one or more of the good books available to help you tune that Holley
