Old 06-21-2003, 10:08 AM
vetklr vetklr is offline
Traveler,
Thanks, I will check the clearance. I don't think there should be a problem, but it wont hurt to check.
I turned on the pump this morning and watched. I could see fuel dripping out of the to front venturies. I shut the pump off and pulled the sight plug and fuel came pouring out. I pulled the float seat, did not see anything wrong but cleaned it anyway. I reset the bowl level and did the back bowl just to be sure. If any thing the back looked a little low. I also check the movement of the float thru the site hole. It appeared to move freely.
I checked the preasure, it stays right at 5lbs.
I will give er a shot again and see what happens. This time I think I will take my wife with me. That way if it quits again, I can make her push while I sit and make vroom noises.
