The higher the compression ratio you run, the bigger the cam has to be to run on pump gas, if that is what you want. The bigger the cam, the lower the torque will be.
Check this out: http://members.uia.net/pkelley2/DynamicCR.html
Good Luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
