Old 06-22-2003, 06:50 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Default Braided Steel
Steve:
Can't address replacing the steel lines with braided steel over teflon but I have done the short line replacement. One of the best secondary advantages of the AN fittings is that they're steel rather than brass so rounding is not a problem. You may have to look around for the proper adapters to marry the AN fittings to the calipers or the existing solid steel lines but, once in, they are a lot easier to work with.
DonC
