Old 06-24-2003, 08:23 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Aluminum or copper/brass, it doesn't affect the cooling ability as much as you might think, only a few percent. (Difference between a 19"x26" and a 19" x 25") The biggest problem is airflow, it doesn't matter how big your radiator is if you don't have a good fan setup. You will run cool on the highway, but get hot in traffic. A good puller fan or two and a SHROUD and you will be ahead of the game.
