Old 06-24-2003, 10:05 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Hi,
I would think that if you went richer replacing the power valve then you have a defect or blockage in the metering plate. OR the accerator pump levers are binding, check that you have 20 thou clearance from lever to adjusting screw on both primary and secondary bowls.
Good Luck,
Perry.
