Old 06-24-2003, 03:19 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I am not familiar with the T56 off the top of my head, but all manual trannys have: and engine plate that goes between the back of the engine and the flywheel, the bellhousing, and some have a cover on the bottom that reveals the bottom third of the flywheel's teeth. You will need to remove the tranny, clutch, disk and flywheel to install a motor plate.
