Thanks guys for the quick responses.
Rick, I looked at your pics and I'm not sure if I have a hole in the same place that you ran your line through- I'll look when I get home. If so, that makes it easy, if not then I'm going with Pat's advice and will look for the smallest grommet that will fit.
Rick, what kind of holddowns did you use to secure the line to the footbox? From the pics it almost looks the the clips for a cable tv wire.
Also, one more quick question. Do you need to bleed the air out of the
oil pressure line to get the gauge to work properly?
thanks again,
Mike
