Old 06-26-2003, 07:29 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
That link pretty much covers it.
DO NOT DRILL OUT THE ALIGNMENT BUSHING HOLES.
keep them their factory size, get the offset dowel pins. The pins need a snug fit, otherwise when you put the bellhousing back on after installing the clutch and pres-plate (removed for runout measurement) the bellhousing will not go back to the exact same spot.
