Old 06-26-2003, 09:27 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Red99Z,
Your best option is to source a factory engine loom and ECU. Find a tuning shop that has LS1 Edit software and get them to disable the VATS (Vehicle Anti Theft System) in the ECU. VATS makes the ECU talk to the BCM (Body Control Module) and verify all the codes match, it's even tied into the ignition key. They can usually mod it so you don't need the BCM at all and the motor will just run with the ECU. The factory Delphi ECU is fully tunable using LS1 Edit so there is no need to use an after market ECU. Check out some of the LS1 forums to learn some more.
I'm not sure what the clutch set up is on your car. I'm using after market master cylinders and I'll need a larger master cylinder to suit the hydraulic throwout. I think 3/4" is the size I need to run.
Mike Murphy
Melbourne Australia
