Old 06-27-2003, 07:32 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Default Wow 750!
That is quite a nice set up you have there! With my 15" wheels there is now way I can fit those brakes!
If you go out to wilwood's site under products/brake pads you will find a pdf that has great charts of the pads CF and temp ranges.
My problem is that I can not run the big rotors, 12.19 is my max and I am going to them, so I need to relie on other factors such as pad CF. Plus since I drive on track tires, all the time, my maximum stoping force needs to be a bit higher than most.
Is dust an issue with the D compound?
Thanks
Rick
OhioCobraClub.com
LondonCobraShow.com
