Old 06-27-2003, 12:32 PM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Question Build specs
Can you tell us what heads, cam, carb and intake manifold you have in this setup?
Cast iron block; which one? I hope 4 bolt mains.
What kind of torque?
What were the rpm's where power was made?
What kind of power curve? I assume that Dynamic ran it on the dyno to show you the numbers.
566hp is impressive!!!!!!!!!!!!!!!!!
I hope that it is "Streetable."
Mine doesn't like anything below 1800rpm with dual plane and 770 Street Avenger, but pulls really strong up to 6000, max 6500rpm. We made 534 ft/lbs @ 4800 rpm; power curve was pretty flat from 3200 up to 4800.
Enquiring minds want to know.
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
