Old 06-28-2003, 09:25 PM
IT could be off a LOT!!! You will need to verify TDC using SOME method other than the timing maker plate to be SURE.
I still think when your done the flat part will face up,,,,,,but you got to be SURE of TDC. Depending on how the cam/crank are set up it COULD go either way, but flat UP I would consider "correct".
Ernie
