Old 06-29-2003, 06:11 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
I use the 7-qt. pan on my 427 so, but with a conventional remote filter plumbed in series with the chin mounted cooler. Cooler remains taped over except for when I use car for high output, i.e., racing. As for a high-volume oil pump, don't use one unless your engine has extremely high oil clearances. High-volume pumps waste power and put a higher load on your engine's timing set. Stick with a standard pump. All "blueprinted" means is the pump has the correct clearances, so a factory stock pump should do the job.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
