Old 06-29-2003, 08:06 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Rear end change Question
Hi guys,
Need a little advice. I have an open 8.8 Ford rear end. I want to change it over to some type of locker. My question is… can I just take out the open carrier (I think that is what it’s called) and replace it with a new carrier? I am not changing the ring or pinion so the setup will remain the same. From what I have heard and read so far it sounds like a simple swap. I plan on replacing the bearings etc. I don’t mind doing it myself but I don’t want to cost myself more money in the end if the alignment is off and I burn up a rear. I know you can check the see how the gears are meshing but that is where my knowledge ends. What is the blue “stuff” called to test how the gears are meshing and what should I look for in the way of alignment?
If the consensus is the alignment will change I will send it out to be done otherwise I will do it myself.
Any insight will be greatly appreciated.
Jim
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
