Old 06-29-2003, 07:39 PM
cobra427mnsi cobra427mnsi is offline
Cobra Make, Engine: Classic Roadster with 427 center oiler
Edsherman
I forgot to add that if you use the HV pump you must use a larger capacity oil pan so the pump does not pump it dry on hard corners or accelerating. Also, if you plan to run a FE you need to restrict the oil to the top of the engine or your rocker covers will fill with oil.
Paul
life is short: eat dessert first !
