Old 06-30-2003, 07:44 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Smaller master = less pressure needed with your left foot. Problem is you will lose travel at the slave because of less volume of fluid being moved by the master. Worst case, you need a smaller bore slave cylinder to gain travel at your TO bearing.
