Old 06-30-2003, 11:29 AM
SFfiredog SFfiredog is offline
CSX 284 Shelby block 4.32" bore
Scat superlight billet crankshaft 4.3" stroke
504 ci
6.7" Oliver billet rods with small block chevy journals
CP pistons 11 to 1 compression
Total Seal gapless top ring set
Petersen 5 stage dry sump oiling system
Billet Fabrications aluminum dry sump pan
Comp Cams 266 int 270 deg exh @ .050" .698 lift 112 lobe center
Schubeck composite lifters
Dove aluminum tunnel port heads, fully ported
Ferrera 2.25 int 1.75 exh valves
Jesel shaft rockers 1.8 ratio
Manton tapered pushrods
I am building an 8 port EFI tunnel port manifold with 58 mm throttle bodies but to start and drive the car initially I have a Nascar Dominator single 4V tunnel port intake with a Pro-Systems
1050 Dominator.
As soon as I stop building other people's cars I should be able to finish mine
--Mike
They bend 'em, we mend 'em.
