Old 06-30-2003, 10:43 AM
CobERA's Avatar
CobERA CobERA is offline
Cobra Make, Engine: ERA #644 428 FE
BB427,
I ordered dual fans from Finish Line but did not like the mounting system, which was essentially two black shelving brackets, between which the fans were mounted.
I used the motors and blades, but fashioned new mounting hardware with pieces I picked up at Home Depot and Sears. (See picture below.) The cross bar is a piece of rectangular tubular steel bar. The fans are attached to the bar with a wide flat "L" shaped decking bracket with a hole in the middle. I trimmed and shaped it a little so that it can not be seen from the front. The end mounting brackets are fashioned from "L" brackets and short lengths of a larger diameter steel bar. I wrapped the ends of the bar with some rubber gasket material I picked up at Sears. With a little WD40, the ends fit perfectly into the mounting brackets and allow for some adjustment of the length of the bar. All the parts cost around 15 bucks.
I may eventually paint the hardware black, but for now I like the polished look.
Hope that helps.
Rick
ERA 644
I'm getting old too fast and smart too slow!
