Old 06-30-2003, 09:21 PM
juanone's Avatar
juanone juanone is offline
Cobra Make, Engine: SPF 1649, Steel Gray with Silver stripes 427W/565hp stroker from Performance engineering
Default Coolant level on Superformance radiator tank
I need help. Just took delivery of SPF 1649 with 427W. I am having trouble with losing the engine coolant. The first time it did it was because I left the valve on the expansion tank open therefore coolant came out. As a result I panicked and bought Coolant and topped of the stainless steel tank. The next day took the car for a ride and everything was going ok until I shut the engine off. Then steam started coming from under the hood and coolant came out again.
I believe that I may have overfilled the tank after the first incident causing the coolant to come out again.
I drained the overflow tank and closed the valve. I have not started the engine because now I don't know how much coolant to add. What should be the fill level on a cold engine in the stainless steel tank of a Superformance?
Any help is welcome.
juanone
Juan Lopez-Bonilla
Kentucky Cobra Club
2432 Crittenden Drive, Suite 201
Louisville, KY 40217
502-635-5711
juanlb@lbrllc.net
