Thread: Reptyl....
  #32 (permalink)
Old 07-01-2003, 08:14 AM
JOHNNYCOBRA's Avatar
JOHNNYCOBRA JOHNNYCOBRA is offline
Cobra Make, Engine: 1984 S-V WITH A 5Liter Eight stack EFI
My 2 cents, I built my 375 stroker based on the standard 9.50
block. minor clearancing on the block, hypereutectic pistons, with stock length rods, compression is about 10:7-1, the real problems were getting the cleavland heads reworked to use on the windsor block. My engine dyno tested at 455HP and 445ft torque
all in at 6400rpm. I believe the newer aluminum heads can produce the same or better numbers and cheaper.
