Old 07-03-2003, 07:22 AM
Roscoe's Avatar
Roscoe Roscoe is offline
Clois,
1. Are you using a power booster? If so what kind?
NO!
2. Are you running a Mustang II front end w/Granada or GM
Metric disc brakes?
Mustang spindle, Grenada Rotor and Wilwood Dyno II Caliper.
3. Are the Porterfied brakes more effecient once they have a little heat in them?
YES! Most pads are.
4. Are you running a portioning valve?
NO! Balance bar. Dual master cyl's
5. Are your rotors drilled and vented?
Not drilled or slotted! Stock Grenada vented rotors
Roscoe
Roscoe
