Old 07-04-2003, 08:21 PM
BT SNAKE's Avatar
BT SNAKE BT SNAKE is offline
Cobra Make, Engine: Midstates Cobra, RFGT40
Thumbs up
Brent, what does the clutch feel like when you push it in. If it
is relitively easy then I think your clutch plate is stuck against the plate and is not releasing. I had the same problem on the GT. A little tap in the right area seemed to do the trick for me. You can also Flump the clutch pedal a number of times. Sometimes this vibrates the plate loose. To flump, press in the clutch pedal then release by sliding your foot off of the pedal allowing the pedal to return with a snap.
I hope this halps.
Hersh
