  #31 (permalink)
Old 07-05-2003, 12:26 AM
decooney's Avatar
decooney decooney is offline
Originally posted by Brent Mills
...This has a strange buzz to it. I didn't let the clutch out, so maybe it's not really fully in gear or something. Not sure why that would be, as I left the linkage on the tranny when I pulled it and didn't adjust. I'm scared.
Brent,
is it possible the linkage rods were bumped when putting the trans back in, where it might be 1/2 way engaged into reverse or part way in another gear or something? Can you get it into reverse, move the car backwards a bit, and then go into 1st and move forwards, and then back to neutral again? I've seen two Toploaders get stuck 1/2 way into other gears and then cleared by using reverse and back out again. Make sure all linkage rods are definitely centered in neutral and start over... just another thought.
Duane
