Old 07-05-2003, 03:08 PM
Sheppard Sheppard is offline
Low oil pressure usually means worn bearings or that something else is worn or broken and that's why low oil pressure is something to be wary of.....10-15 psi at idle may not be detrimental...."low" oil pressure is relative, if you have 10-15 psi at speed you have low pressure. Obviously 10-15 psi is less than many who have 30 or so at idle. However.....I would get a hold of George at Gessford and get his thoughts before I yanked the engine.......
GOOD LUCK!
