Old 07-06-2003, 08:31 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
IMHO,
You aren't losing 35-40 psi at the lifters. It might be costing you 6-8. I'm not suggesting you shouldn't do it, it just might not be all that you hope it is. You may have a standard oil pump installed instead of a HV pump.
I had a similar problem on a fresh 428. My oil pressure was 45-50 cold, 25-35 hot. I pulled the pan and the shop had indeed installed a standard oil pump. My oil pressure went to 70-75 cold to 45-55 hot.
Good Luck
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
