Old 07-07-2003, 05:34 AM
ForumHopper ForumHopper is offline
Smile *Any responce helpful* Need info for CG Cobra 427 SC
Hi! Hope Someone can help me. I have an odd request.
I'm building a 3d computer graphic Cobra 427 SC and I need more information about the origional car in order to make it more authentic. I've done a lot of research for this project already, but there are some bits of info I've not been able to find. I wonder if you would be willing to help me out? It would be much appreciated! I will provide a High res. downloadable copy of the completed image to those who provide the info I need.
This is what I know I need:
1. Dementions for the front openings, height and width (inches).
2. Height/width of the hood scoop opening (as origionaly designed).
3. The distance between the headlights from center to center.
4. The distance between the taillights from center to center.
5. Width of the body at the point just aft of the front fender flare and before the side pipe opening (above the rounded edge).
6. I need the tread pattern for the OEM Good Year Speedway Special tires (if possible. if not, don't worry).
Also Would you mind having a look at these images to tell me what they need to be more like OEM. Some of them were made using replica parts for referance.
http://lennon.csufresno.edu/~rwv01/sidepipe_gascap.jpg
http://lennon.csufresno.edu/~rwv01/windshield_frame.jpg
http://lennon.csufresno.edu/~rwv01/bucket_seat.jpg
http://lennon.csufresno.edu/~rwv01/bullet_mirror.jpg
http://lennon.csufresno.edu/~rwv01/moreparts.jpg
http://lennon.csufresno.edu/~rwv01/S...ment_panel.jpg
http://lennon.csufresno.edu/~rwv01/parts_shifter.jpg
Here's an extrememly rough screen shot of the car at it's current stage. These colors are temporary. It's gonna be Guardsman Blue and Wimboldon White (right?) if the hex codes I have are correct.
Thank you for your help and advice!
