Old 07-08-2003, 05:52 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Gerry - is the engine REALLY at TDC when the pointer and the marks on the crank damper say so?
Is it a rubber bonded type damper? Could the outer rim have spun on the rubber?
Probably worth checking the real TDC position using a bolt down the No 1 spark plug hole. Then you can at least eliminate incorrect timing.
Also, do you have an MSD ignition? They can sometimes give spurious results with some timing lights.
HTH
Wilf
